Posts: 2185 http://meble-kuchenne.info.pl
Has thanked: 177 times
Been thanked: 1026 times
Post
by mnfisher » Sat May 10, 2025 7:14 pm
Sorry , I just noticed that you got the wdt issue when writing to i2c in a loop (I hadn't read it as 'just' writing to i2c in a loop at the beginning)
That make it even stranger
Posts: 1300 Joined: Wed Dec 02, 2020 10:53 am
Has thanked: 246 times
Been thanked: 258 times
Post
by stefan.erni » Tue May 13, 2025 9:22 am
Hi Martin
Yes, that too: In an almost identical program this works perfectly. I can also write to both IMUs.
Posts: 2185 Joined: Wed Dec 09, 2020 9:37 pm
Post
by mnfisher » Tue May 13, 2025 9:27 am
I didn't get an issue with the above example - just multiple writes to i2c as expected.
So what changed?
I notice a comment about the RGB LEDs initialisation not working in a macro too - more weirdness...
Post
by stefan.erni » Fri May 16, 2025 4:17 pm
Hi Martin
My program works again!
I can set the LSM6 with I2C master and I can read LSM6 with I2C master
I had to set all I2C components to ch2!
With almost the same program on I2C ch1 it works fine...
Thank you very much for your support Martin.
for the RGB Led I wrote a new post:
https://flowcode.co.uk/forums/viewtopic.php?t=3153
