MAX7219 32x32 LED Display
kaqkk007
- Has thanked: 4 times
- Been thanked: 4 times
Re: MAX7219 32x32 LED Display
Is it possible that the display is interfering with the RTC's operation? I'm using the display on Channel 1 and the DS3231 on pins RB0 and RB1. It reads and displays the values, but I can't configure the RTC.
- max7219_4DIG.7.fcfx
- (32.95 KiB) Downloaded 956 times
- Has thanked: 165 times
- Been thanked: 966 times
I think the issue is that you are calling RTC nearly 20,000 timer per second.
I would try and move the RTC setting to outside of the interrupt handler (possibly set a flag in the interrupt handler 'set_clock') and test this in main - or set an interrupt on the button presses and test for this in main)
I'd also reduce the 'update' rate of the display (once per second should be sufficient?)
It works in other classes whether I call it from an interrupt or run it from the main program, so I don't understand why it doesn't work here (just the setup); reading the value works perfectly.The refresh rate is set to once per minute, and that's when I set the value
- max7219_4DIG.8.fcfx
- (28.63 KiB) Downloaded 959 times
