Grove Ultrasonic Ranger and Timer Issue
ConnorTron110
Post by ConnorTron110 »
Hello, I've found a problem with 2 components when they are combined together.
Those components are the Ultrasonic Ranger (Grove 101020010) and the Timer (in the storage component library)
Individually these components work as expected however both placed in the environment with the Arduino Uno board seems to produce an error when compiling to Hex therefore unable to compile to the board.
Is there any workaround to this issue as I need both for my project, thanks in advance!
Has thanked: 795 times
Been thanked: 858 times
Re: Grove Ultrasonic Ranger and Timer Issue
Hi.
Can you post your project file (.fcfx extension), so we see what's going on?
ConnorTron110
Yep, here's a project with the two components mentioned, if you try to compile to hex (or to target) you will see the issue on the log :)
Issue Project.fcfx
(8.55 KiB) Downloaded 519 times
chrisd958
Post by chrisd958 »
Yes, I have the same problem and I spent over 2 hours on it before reading this. The thread seems to have gone quiet - is there a workaround or can a different timer be used with Arduino Uno R3 PDIP? I want to use 'ping' and time the measurement. We spent good money on EBlocks2 & Flowcode!
Has thanked: 647 times
Been thanked: 856 times
This problem is caused by two things.
1) the timer component is clashing with the free timer component nested inside the ultrasonic component.
warning: "TIM_1_INC" redefined
I have now edited the free timer component to remove this clash and pushed the change to the update system.
2) the timer and the ultrasonic component timer are both pointed at the same timer resource (timer1).
error: redefinition of '__vector_9'
The ultrasonic component is set to time measurement using delays but the definitions for the underlying hardware timer are still active. I haven't yet been able to solve this one for you so you can either change the timer connected to the timer component or you can temporarily change the time measurement of the ranger component to allow you to assign a different timer peripheral.
I might try and solve problem 2 for you but this is a very corner case issue so I might leave it as it is for now.
