Show macro when made
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
There seems to be a difference between FC9 and the previous versions?
I've added an interrupt that calls a new macro. The new macro is created in the interrupt properties window.
The macro is given a name and after that, the macro doesn't show up automatically.
Is it possible to investigate this so that when a new macro is created via an interrupt, it isn't hidden?
Has thanked: 795 times
Been thanked: 858 times
Re: Show macro when made
Hi.
The macro shows up after you select OK & Edit Macro.
You will also see the macro when you select Macros from Project explorer:
User Macros.png (8.75 KiB) Viewed 5127 times
MJU20
Post by MJU20 »
Thank you Medelec35.
I must be getting old.
In previous versions of FC I always used this. How can I miss this feature in this version?
I have been cursing for a few projects in FC9, but it seems I've missed it al this time.
My excuses for this.
Hi.
Not a problem.
I have moved the topic from Feature requests to General.
