Calculation order
Has thanked: 158 times
Been thanked: 943 times
Calculation order
Post by mnfisher »
Not sure if this has been reported before - but it's just caused me some debug grief.
Trying out an algorithm in the simulator I have
.Return = .a + .b / 2
Which on hardware I would expect to give the answer, say for .a = 10 and .b = 20, of 15..
In the simulator it doesn't - it gives 25 (so it's doing .Return = .a + (.b / 2))
Tested under v8 and it's also a problem there.
bodmas.fcfx
(7.2 KiB) Downloaded 682 times
Has thanked: 278 times
Been thanked: 445 times
Re: Calculation order
I think that's correct. in BODMAS, the "D" (divide) takes precedence over the "A" (add).
So
z = a + b / c
will be calculated as
z = a + (b / c)
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
Sounds like perfect order in which the operands should be applied to me.
Division has higher priority and is performed first. If you want to make sure things are done in the order you expect always use parenthesis.
Post by mnfisher »
Yes - having a bad day on the math front! :oops: what a numpty....
It is (of course) doing it perfectly and my brain isn't.....
What I wanted was (.a + .b) / 2 and that was what I used in the end... Sadly .Return = 0 would have probably worked just as well ;)
(see https://www.flowcode.co.uk/mmforums/view ... 26&t=20604)
Lesteraction
Post by Lesteraction »
Division is completed first since it is more important. Always use parentheses if you want to ensure that things are completed in the sequence you anticipate.
