ESP32 TOOLCHAIN Installation has failed with exit code -2
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello Flow Code Team,
I´m in the phase in order to evaluate the new FC9 Main interest is at the moment the new ESP32 part.
Plan would be to purchase a professional version FC9 because I could upgrade from FC professional.
I´ll tried to install the ESP32 TOOLCHAIN, but it ended up always with the following error message:
I tried a installation at a WIN8 and a WIN10 PC. Same result, same error code.
May sombody can help.
Attached is the installation log file.
BR and THX in advance
Dirk
Setup Log 2021-01-05 #001.txt
(30.4 KiB) Downloaded 814 times
Happy FC9, FC-8 and FC-6 professional user ;)
dvcam99
Re: ESP32 TOOLCHAIN Installation has failed with exit code -2
Post by dvcam99 »
...add on note. A PIC-8 TOOLCHAIN installed correctly and it is possible to compile.
BR
Dirk
Has thanked: 633 times
Been thanked: 837 times
Hi Dirk,
Do you already have Python or Git installed on your system?
Googling the problem I found a couple of pages but not sure if they will be helpful.
https://www.esp32.com/viewtopic.php?t=12481
https://github.com/espressif/esp-idf/issues/5979
We have had a report that if running the ESP IDF tools we are hosting is failing then downloading the latest from the Espressif website works ok.
dvcam99
Post by dvcam99 »
Hello Ben,
no I had not installed Git and Pyton at my system.
I´ll try the Espressif version.
BR
Dirk
dvcam99
Post by dvcam99 »
Hi Ben,
I can report succes with Espressif ESP-IDF 4.2.
Build completed successfully
FINISHED
Short workflow how I did it.
1. Downloaded the Version 4.2 from the follwing link:
https://www.espressif.com/en/support/do ... %5B%5D=624
2. Unizip in a working folder an copied the extract in a empty folder i.e. C:\esp-idf
3. Run you installer 2.3 and assigined/use C:\esp-idf as a existing directory
4. Follow all other steps like you have defined in you ESP-IDF installation procedure (PDF document)
https://flowcode.co.uk/wiki/index.php?t ... ctions.pdf
5. Cross Check with the compiler, done!!
BR
Dirk
Hi Dirk,
Brilliant good result there, many thanks for letting us know. Really appreciate it :D
