String initialization in simulation
Has thanked: 177 times
Been thanked: 1026 times
Post by mnfisher »
Just noticed that string initialisation doesn't seem to work correctly in simulation...
So if I declare a variable test as a string with initial value "ABCD" it is empty.
The code generated looks good however - so should work on the MCU...
init.fcfx
(8.81 KiB) Downloaded 344 times
Just sends "\r\n" to UART in simulation.....
Has thanked: 311 times
Been thanked: 479 times
Re: String initialization in simulation
Thanks for letting us know about this. I actually fixed this issue in the v10 codebase about 4 months ago as part of a large change to better support strings.
I've just rolled out a simple fix for the v9 codebase, so this should work when a future version of the exe is released.
