4D Picaso V1 component issues
wardelder
Post by wardelder »
Using my EB091 board I tried to compile a very basic program for a 4D systems LCD running the Picaso processor. The code only has one component macro: the gLCD Initialise component. I get an error in the linker.
Here is the output from the build:
Target folder: C:\Flowcode
Source name: C:\Flowcode\V9_EB091_Picaso1.fcfx
Title:
Description:
Device: PIC16.33E.EB091
Generated by: Flowcode v9.0.0.23
Date: Tuesday, January 05, 2021 20:07:00
Users: 1
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode\Compilers\pic16\batchfiles\pic16_C30_comp.bat "V9_EB091_Picaso1" "C:\Flowcode\" "33EP256MU806"
C:\Flowcode>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\Flowcode\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\Flowcode\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "V9_EB091_Picaso1".c -o "V9_EB091_Picaso1".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
V9_EB091_Picaso1.c: In function 'FCD_047c1_gLCD_4D_v1_Picaso1__Print':
V9_EB091_Picaso1.c:3205:2: warning: implicit declaration of function 'FCD_0ba71_Base_GLCD__Print'
V9_EB091_Picaso1.c: At top level:
V9_EB091_Picaso1.c:3977:1: warning: '_FGS' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FOSCSEL' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FOSC' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FWDT' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FPOR' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FICD' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FAS' definition has been deprecated: consider migrating to #pragma config
V9_EB091_Picaso1.c:3977:1: warning: '_FUID0' definition has been deprecated: consider migrating to #pragma config
Compilation successful!
C:\Program Files (x86)\Flowcode\Compilers\pic16\batchfiles\pic16_C30_link.bat "C:\Flowcode\V9_EB091_Picaso1" 33EP256MU806 33E
xc16-ld 1.26 (A)
Program Memory [Origin = 0x200, Length = 0x2aa00]
section address length (PC units) length (bytes) (dec)
.text 0x200 0x456 0x681 (1665)
.const 0x656 0x2 0x3 (3)
.text 0x658 0x1208 0x1b0c (6924)
.dinit 0x1860 0x8 0xc (12)
Total program memory used (bytes): 0x219c (8604) 3%
Auxflash Memory [Origin = 0x7fc000, Length = 0x3ffa]
Total auxflash memory used (bytes): 0 (0) <1%
Data Memory [Origin = 0x1000, Length = 0x7000]
section address alignment gaps total length (dec)
.nbss 0x1000 0 0x36 (54)
Total data memory used (bytes): 0x36 (54) <1%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0x1036 0x6fca (28618)
Maximum dynamic memory (bytes): 0x6fca (28618)
C:\Flowcode\V9_EB091_Picaso1.o(.text+0xd94):C:\Flowcode\V9_EB091_Picaso1.c: undefined reference to `FCD_0ba71_Base_GLCD__Print'
Error returned from [xc16-gcc.exe]
C:\Program Files (x86)\Flowcode\Compilers\pic16\batchfiles\pic16_C30_link.bat reported error code 0x1
Autoclose turned off
FINISHED
(7.92 KiB) Downloaded 500 times
Has thanked: 587 times
Been thanked: 773 times
Re: 4D Picaso V1 component issues
THanks for letting us know.
Hopefully should be fixed for you now.
wardelder
Post by wardelder »
It now works. I am using the Visi4D component as it gives more functionality on the 4D display I am using. Thanks for the quick fix!
