I2C Sniffer
Has thanked: 778 times
Been thanked: 839 times
I2C Sniffer
Hi.
Attached is an I2C sniffer that displays details of one or more I2c connected devices.
Sniffer was created on the Uno but it works with 8bit pic as well.
The image shows 3 devices captured.
0x3F [63] is a backpack LCD.
0x56 [86] is a 24C32 EEPROM.
0x68 [104] is a DS3231 RTC .
Note: The I2c addresses scan will repeat every 5seconds.
IC2 Address Sniffer v3.fcfx
(21.51 KiB) Downloaded 601 times
Re: I2C Sniffer
Some nice improvements for v3
canary_wharfe
Has thanked: 15 times
Been thanked: 16 times
Re: I2C Sniffer
Post by canary_wharfe »
Hi Martin
Just wondering whether your sniffer could test SHT31 humidity/temp sensors? Those sensors transmit both humidity and temp bytes so just wondering if your sniffer would be able to differentiate between the two or whether it would need modifying to interface to the SHT?
< The Flowcode 11 Pro Silicon Chipper >
Re: I2C Sniffer
The sniffer only captures the device's main address and not the individual registers e.g temperature, humidity, pressure, etc.
Its purpose is if you have a device with settable addresses e.g backpack LCD then the correct address will be displayed.
canary_wharfe
Re: I2C Sniffer
Ah! thanks Martin. I had a quick look over your flowcode and that's what I thought but thought I'd check by asking.
BTW. That's a very nice bit of flowcoding there :-)
