I've started to add an infrared remote function to my latest project, using the RC5 component from the commsb library.
The problem is that RC5 is pretty much an obsolete protocol.
Most AV equipment for instance uses a later developed version like RC6, NEC, Panasonic, what have you.
See for instance the attached.
I'd like to make the case to extend the current RC5 'component' so that several more current protocols, as well as the carrier frequency (beyond only 36kHz) can be selected.
Much obliged!
Jan Didden
Linear Audio
Extension of RC5 remote transmitter/receiver component in commsb library
jan.didden
- Has thanked: 20 times
- Been thanked: 12 times
- infrared_protocols_samples.pdf
- (87.94 KiB) Downloaded 535 times
