The default thermistor component appears to be a positive coefficient thermistor. How do i change the component to use a negative coefficient thermistor? Is it as simple as entering the resistance values to suit the one I have or is there more required?
Im using what I think is a vishay thermistor which is 10k at 25 deg but I'm having difficulty finding a table which shows the resistance at the different temperatures. Dont know where i got them but its all i have atm so if anyone has a table Id be grateful if you would share. I have the attached datasheet but its not easy to interpret
Also how can i get my display to show the deg symbol ° (alt 248) its just showing 3 horizontal lines in both simulate and display?
N
Q about the thermistor component
WingNut
- Has thanked: 54 times
- Been thanked: 43 times
- Has thanked: 633 times
- Been thanked: 837 times
Re: Q about the thermistor component
Hopefully this should be implemented now with the latest component updates, what GLCD font are you using?Also how can i get my display to show the deg symbol ° (alt 248) its just showing 3 horizontal lines in both simulate and display?
To be honest Ben i just implemented your solution with the hex values as Im still trying to work out something for the st7735 display and managed to get sucked into another working circuit allbeit a very slow display update (14secs). Still fiddling with the ili9163 macros you sent me
