Hello Everyone,
We are going to be working on some applications for electrical test to help demonstrate the power of app developer in Flowcode 9 and also to create some examples that are easy to follow and hopefully inspire some more knock on projects.
The first project we had in mind is an Arduino Uno based component tester that can get the value of resistors and capacitors as well as maybe testing out diodes and transistors. This would all be controlled via an App developer app alongside the Arduino USB slave firmware. In th next few days I'll create a simple circuit to go on the Arduino as well as a App Developer program and a video to showcase the project.
Is there anything specific that anyone would like to see being implemented as part of this project or even turning into a seperate project for next time?
Electrical Test Projects
- Has thanked: 647 times
- Been thanked: 856 times
Re: Electrical Test Projects
Hi Jac,
Yes good shout I'll have a go with coils too to get their resistance and inductance.
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
Hi Team,
Nice idea however my question is why must it always be based on an Arduino just asking
I also like jgu1 idea, transistors MOSFET test will be interesting
Out of interest what MCU would you like to see and maybe we can base our next project around this?
We wanted to use some hardware that is very easy to get hold of and also most people might already have one sat in a drawer. The project should work equally well on just about any MCU with analogue and digital pins and a connection back to the PC. One of our other SCADA slave targets for example would work just as well e.g. ECIO, ESP32 or dsPIC E-blocks2 board to name a few.why must it always be based on an Arduino
- Has thanked: 311 times
- Been thanked: 479 times
That question highlights what I believe is one of the more powerful aspects of Flowcode: projects can easily be transferred to other targets, often with few or no coding changes. We probably don't push this enough.
So while this project will be written around an Arduino, it should be simple to port to another platform or chip.
- p.erasmus
Hi Team.
Thanks guys make sense and I understand your view
I think we very little push the dsPICs, which has a lot of potential although a 16bit mcu these out perform many 32bit mcus,Out of interest what MCU would you like to see and maybe we can base our next project around this?
Hi Peter,
I agree the 16-bit PICs are little powerhouses
They are certainly one of my go to devices.
I've made a start on the component test project here if anyone would like to have a go or try and help push the project forwards.
viewtopic.php?f=3&t=117&p=579
