Modify Option register at PIC16F627A with C-Box?
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello Matrix Team,
may you can help me with the above issue.
The PIC16F627A has the feature to activate the internal pulup resistors. I would like to use this feature for the complet RB-Port or may better for individual pins at the RB-Port.
May somebody can help me with the necessary C-command.
The rigister bit is number 7
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 752 times
Been thanked: 814 times
Re: Modify Option register at PIC16F627A with C-Box?
Hi.
I have given an example here
Are you ok with the C code to set the individual pins with a pull-up?
dvcam99
Post by dvcam99 »
Hi Martin,
many thanks for the replay. Not sure if I do it right. Placing the following statment inside C-Box...
OPTION_REGbits.nWPUEN = 1;
...will create the following compiler error message....
Microchip MPLAB XC8 C Compiler (PRO Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Copyright (C) 2017 Microchip Technology Inc.
Old_GSU_for_new_ECU_V1_7_1.c: main()
3008: OPTION_REGbits.nWPUEN = 1;
^ (255) not a member of the struct/union ""
^ (182) illegal conversion between types
int -> volatile union S31
(908) exit status = 1
Error returned from [xc8.exe]
Autoclose turned off
FINISHED
BR
Dirk
Hi.
what I posted was a link to a guide to point you in the right direction of how to use C code.
It will vary depending on the target.
In your case of the 16F627A the datasheet shows:
So instead of
you will need to use
OPTION_REGbits.nRBPU = 1;
dvcam99
Post by dvcam99 »
Yes many thanks Martin,
with RPBU it is working!!! :D
BR
Dirk
dvcam99
Post by dvcam99 »
...i mean RBPU !!!
