running a DC motor using the arduino motor shield
Has thanked: 512 times
Been thanked: 472 times
Re: running a DC motor using the arduino motor shield
The period register is misleading on the AVR range as it's always fixed at 256, there no period control register.
Therefore, as the period on PWM and the motor shield only shows 0 to 255 and not 256, the frequency displayed will not be correct.
It's not anything you are doing wrong.
You should see a warning about the period control register when compiling.
Has thanked: 285 times
Been thanked: 412 times
Hi Martin
Thanks for the clarification. I'll check the compiler messages later too.
peterhalloway
Post by peterhalloway »
Hi Martin
I have updated flowcode reprogrammed the arduino but still the motor does not turn. I also did not get a compiler warning. I am sure there is something simple I am doing wrong?
Pete
Try the attached.
Do you have a logic analyser or scope? If so look at the output pin on the Uno, it should show a 50/50 square wave. If not perhaps try an led with a resistor in series. It won't flash but if you change duty to 255 it should then be brighter than 128. This will at least prove your Uno is functioning.
DC motor_Test_1.fcfx
(9.97 KiB) Downloaded 70 times
peterhalloway
correction the motor is now running thank you can you please explain what I did wrong
