Network Comms not supported with WLAN ESP32
wardelder
Post by wardelder »
When I try to connect the Network Comms to the WLAN ESP32 component, the Network Comms component properties shows "Not Yet Supported" in the Status field. Will there be support soon?
Has thanked: 606 times
Been thanked: 803 times
Re: Network Comms not supported with WLAN ESP32
It should already be supported, that message may be an oversight, I'll investigate for you.
wardelder
Post by wardelder »
When I try to compile I get multiple errors. I have attached the program and errors.
ESP32_WLAN Errors.txt
(47.82 KiB) Downloaded 887 times
V9_ESP32_WiFi_Test.fcfx
(20.64 KiB) Downloaded 866 times
Many thanks for letting us know.
I have fixed some of the problems now including the Nework commsa saying ESP32 Wifi is unsupported and some of the generated Errors. Currently talking to Leigh about the other errors and how we can fix them. They are very minor but the ESP compiler by default is very picky about things.
While we get this sorted you can make your compiler less strict by following the instructions below.
File to edit is IDF_Folder\tools\cmake\build.cmake
Section starts with this
list(APPEND compile_options
Here are the settings I'm now using to get around the error and to remove some of the warnings.
    list(APPEND compile_options     "-ffunction-sections"
                                    "-fdata-sections"
                                    "-fstrict-volatile-bitfields"
                                    "-nostdlib"
                                    # warning-related flags
                                    "-Wall"
                                    "-Werror=all"
                                    "-Wno-error=pointer-sign"
                                    "-Wno-error=unused-function"
                                    "-Wno-error=unused-but-set-variable"
                                    "-Wno-error=unused-variable"
                                    "-Wno-error=deprecated-declarations"
                                    "-Wextra"
                                    "-Wno-unused-parameter"
                                    "-Wno-unused-function"
                                    "-Wno-unused-variable"
                                    "-Wno-discarded-qualifiers"
                                    "-Wno-pointer-sign"
                                    "-Wno-sign-compare"
                                    # always generate debug symbols (even in release mode, these don't
                                    # go into the final binary so have no impact on size
                                    "-ggdb")
The lines I have added are,
"-Wno-error=pointer-sign" - this is the only one to get it to compile succesfully.
"-Wno-pointer-sign"
Let us know how you get on if you decide to do this and I'll see if we can solve the problem here.
wardelder
Post by wardelder »
That worked! I can now create and run a webserver from the ESP32. Thank you!
Has thanked: 101 times
Been thanked: 299 times
The original errors have now been fixed.
The above work-around is no longer required.
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello Matrix Team,
I´ll tried to compile the above example programm to compile an use as a tutorial for me, but unfortunately I´ll get the following compiler messages.
Target folder: C:\Users\db\Downloads
Source name: C:\Users\db\Downloads\V9_ESP32_WiFi_Test (1).fcfx
Title:
Description:
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v9.0.0.23
Date: Wednesday, January 20, 2021 16:41:00
Users: 1
Registered to: dvcam99 (dvcam99)
Licence key: e();
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\ESP\Batch\esp32_build.bat "C:\esp-idf\" "V9_ESP32_WiFi_Test (1)" "C:\Users\db\Downloads\" esp32s_sdkconfig
Building V9_ESP32_WiFi_Test (1) ...
Setting IDF_PATH: C:\esp-idf
Adding ESP-IDF tools to PATH...
C:\dbu\.espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin
C:\dbu\.espressif\tools\xtensa-esp32s2-elf\esp-2020r3-8.4.0\xtensa-esp32s2-elf\bin
C:\dbu\.espressif\tools\esp32ulp-elf\2.28.51-esp-20191205\esp32ulp-elf-binutils\bin
C:\dbu\.espressif\tools\esp32s2ulp-elf\2.28.51-esp-20191205\esp32s2ulp-elf-binutils\bin
C:\dbu\.espressif\tools\cmake\3.16.4\bin
C:\dbu\.espressif\tools\openocd-esp32\v0.10.0-esp32-20200709\openocd-esp32\bin
C:\dbu\.espressif\tools\ninja\1.10.0\
C:\dbu\.espressif\tools\idf-exe\1.0.1\
C:\dbu\.espressif\tools\ccache\3.7\
C:\dbu\.espressif\tools\dfu-util\0.9\dfu-util-0.9-win64
C:\dbu\.espressif\python_env\idf4.2_py3.7_env\Scripts
C:\esp-idf\tools
Python requirements from C:\esp-idf\requirements.txt are satisfied.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.21.0.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/dbu/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/dbu/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/dbu/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/dbu/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/dbu/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32
CMake Error at C:/esp-idf/tools/cmake/component.cmake:221 (message):
CMake Warning (dev) at build_properties.temp.cmake:24:
Syntax Warning in cmake code at column 59
Argument not separated from preceding token by whitespace.
Call Stack (most recent call first):
C:/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:1 (include)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at build_properties.temp.cmake:25:
CMake Warning (dev) at build_properties.temp.cmake:2 (set):
Syntax error in cmake code at
C:/Users/db/Downloads/V9_ESP32_WiFi_Test_(1)/build/build_properties.temp.cmake:2
when parsing string
C:\dbu\.espressif\python_env\idf4.2_py3.7_env\Scripts\python.exe
Invalid escape sequence \d
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
CMake Warning (dev) at component_properties.temp.cmake:671:
Syntax Warning in cmake code at column 87
C:/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:2 (include)
CMake Error at
C:/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:60
(include):
include called with wrong number of arguments. include() only takes one
file.
C:/esp-idf/tools/cmake/scripts/component_get_requirements.cmake:76 (__component_get_requirements)
C:/esp-idf/tools/cmake/build.cmake:405 (__component_get_requirements)
C:/esp-idf/tools/cmake/project.cmake:395 (idf_build_process)
CMakeLists.txt:6 (project)
-- Configuring incomplete, errors occurred!
See also "C:/Users/db/Downloads/V9_ESP32_WiFi_Test_(1)/build/CMakeFiles/CMakeOutput.log".
Running cmake in directory c:\users\db\downloads\v9_esp32_wifi_test_(1)\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 c:\users\db\downloads\v9_esp32_wifi_test_(1)"...
cmake failed with exit code 1
Build Failed
Autoclose turned off
FINISHED
Happy FC9, FC-8 and FC-6 professional user ;)
dvcam99
Post by dvcam99 »
Hello Matrix Team,
Title:
Description:
Users: 1
Licence key: e();
C:\esp-idf\tools
idf.py build
when parsing string
CMake Error at
(include):
file.
Build Failed
FINISHED
It looks like the ESP toolchain does not like brackets (parentheses)
try changing the project name from v9_esp32_wifi_test_(1) to v9_esp32_wifi_test_1
