Ds18B20 x2 Flowcode v5-v6-v9
Dazaly18
Post by Dazaly18 »
I have a working system literally out in the field for the last 4 years using 2 x DS18B20 with 2x16 LCD hardware proving to be very reliable.
This was coded with flowcode 5 tried the code with flowcode 6 and this also works.
Tried the same code with flowcode 9 (Open trial) before I upgrade and found the DS18B20 are not providing the temp.
Have changed multiple config settings and combinations trying to get the v9 version to work.
Can someone help and spot the issue, attached just the basic temp code.
Thanks D
DS18B20 Temp Flow v9.fcfx
(27.53 KiB) Downloaded 163 times
Has thanked: 724 times
Been thanked: 783 times
Re: Ds18B20 x2 Flowcode v5-v6-v9
There is an example on the Wiki that allows multiple DS18B20 sensors
