Flowcode is off screen after creating or opening a project
Has thanked: 311 times
Been thanked: 479 times
There is a known issue in Flowcode where it seems to disappear after creating or loading a project. This can happen if the monitor setup of your system has changed since you previously used Flowcode (e.g. you sometimes plug an external monitor into your laptop).
The reason is that Flowcode retains two sets of windows position information - one when a project is loaded, and the other when there is no project loaded. The window position information for the loaded project may relate to a position off-screen on the current monitor setup.
If you experience this issue, right-click the Flowcode icon on the Windows taskbar while holding down the shift key and select "move". You can then move the mouse to reposition the Flowcode application onto your screen.
This issue also affects other Windows applications and more information can be found by searching for "off screen windows" in your favourite search engine.
