Float Rounding Problem
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Post by wayne_millard »
Hi Matrix Team,
Im having some problems with Float Rounding. I have attached an example file.
What am i doing wrong? Only one of the roundings seem to do something.
Thanks,
Wayne M
Float Rounding.fcsx
Float Rounded Problem
(8.34 KiB) Downloaded 486 times
Has thanked: 618 times
Been thanked: 818 times
Re: Float Rounding Problem
Hello Wayne,
It looks like it's working in the simulation, but maybe the precision of storing and displaying the number is not ideal. I beleive this is the limitation of the float format rather than anything else.
This is a nice tool as it allows you to enter a real number and it will show you the floating point representation of the number.
https://www.h-schmidt.net/FloatConverter/IEEE754.html
100.7 is actually stored as 100.6999969482421875
100.68 as 100.68000030517578125
etc
wayne_millard
Has thanked: 1 time
Hi everyone
What I wanted was to only display to two places after the decimal point.
I thought in the past when you did a round to two decimal places you would loose all the other numbers.
So how do you do it.
Wayne m
Has thanked: 165 times
Been thanked: 965 times
Post by mnfisher »
Hi Wayne,
Try using str = FloatToStr$(val, 2)
Then display the string str.
wayne_millard
Has thanked: 1 time
Martin, Thanks I forgot about that.
Wayne
