EBM016 Humidity Sensor - no longer works after latest update on Flowcode V9
SuffolkOne
Has thanked: 2 times
Post by SuffolkOne »
Have been using the E-blocks (first version) kit for several years. Have many programs that have worked with the humidity sensor, but since the last component update (that pops up in the bottom right when adding a component), 2 things have happened:
1) the appearance of the sensor looks different on the viewer.
2) although the simulation works, the actual compiled program no longer works on E-blocks.
We have laptops that have not been updated, and the programs still works when compiled off those, so it definitely the update that has changed something.
Has there been a change in SDA or SCL settings? Is there a way to roll back these updates, as the students are starting their exams next week.
Has thanked: 795 times
Been thanked: 858 times
Re: EBM016 Humidity Sensor - no longer works after latest update on Flowcode V9
Thank you for the spot and sorry for any issues the update has caused.
Yes, you can rollback.
If you Select Help, Library Updates
Click on Show up-to-date files.
Make sure Files in-use is selected.
Scroll down to components and click on EBM016_Humidity.fcpx
In the New Revision section select the dropbox and change to a previous version.
In your case, it will be 2.
When the change has been completed, you will need to reload your flowchart for the change to take effect.
SuffolkOne
Thank you, the rollback worked.
Hopefully not something that is going to happen with all the components when updated...
Would be panic stations during the exams!
Luckily, it does not normally happen.
It will be looked into and fixed.
Thank you for letting us know the rollback worked.
I have updated the EBM016 and it has now been pushed onto the update system.
It will be available by selecting Help, Library Updates....
Can you please let me know if the updated file (Revision 4) works OK or not?
