HI
thank you very much for your job and the very fast answers, loaded the component but the connection pins are disapper again
DS3231 ALARM
- Been thanked: 5 times
- Has thanked: 512 times
- Been thanked: 472 times
Re: DS3231 ALARM
Hi Martin.
I can see if I can get to look right if you would like to post or PM the source, along with any used images.
Re: DS3231 ALARM
many thanks to all
the component seems to me that it works well and you can also see the new icon, I could not test all its features, also because it would take a manual to do this, but it is read / written, and the alarm every minute with reset works with ESP32 , now I'm waiting for the new RPY PICO board to arrive and hope it works well there too, I'll let you know
Thanks mnfisher and Medelec35
Re: DS3231 ALARM
Hello everyone
I was able to test the RTC ds3231 component on RPI Pico but the alarms do not work while the reading and writing of the time and date work, the strange thing is that it no longer works even on ESP32, the output always remains at 0, if I do not have wrong should bring to 1 at the end of the minute, at the moment I have not inserted the reset alarm I am attaching the test file ESP32 so that you can see if I have done something wrong
thank you
thank you
- ESP32_RTC_DS3231_test2.fcfx
- (14.44 KiB) Downloaded 186 times
- Has thanked: 104 times
- Been thanked: 509 times
Re: DS3231 ALARM
Sorry - missed this message....
I'm not sure - what are you trying to achieve? I don't have a Pico to test on - but it doesn't look in the code as though you are accessing the alarm signal - just outputting time etc every 500ms..
What result are you getting - and what should you get here?
Re: DS3231 ALARM
hello mnfisher
yesterday I saw your post and I picked up the ds3231 again and on ESP32 it started working (at the stroke of the minute I saw the ESP32 output lower and then return to high and this happened every minute) I was happy but confused because it was a while I got nothing out of the way, and then suddenly there it was. at this point I create the same program for RPI PICO, I connect the DS3231 but nothing comes out, I reconnect the DS to the ESP32 but I have no response from the output, I recreate the same program for an old arduino 2560 I read the date and time but the output does not respond, on this file I added an interrupt that is connected to the DS output that turns on a led in case it goes from a high to low logic level
I am attaching the file
thank you
thank you
- 2560_RTC_DS3231_test2.fcfx
- (16.55 KiB) Downloaded 178 times
