I've seen in a flash an article that the ESP32 could be used as a MQTT broker.
Is this true?
Could this become a Flowcode component?
ESP32 as MQTT broker?
MJU20
- Has thanked: 105 times
- Been thanked: 76 times
- Has thanked: 633 times
- Been thanked: 836 times
Re: ESP32 as MQTT broker?
Yes I don't see why not, but it's not simple and security could be an issue. Making a component for a MQTT broker woulld be a fairly big job though certainly not impossible.
One question might be why when there are lots of maintained brokers out there already for free both on the internet and also locally on things like a RPI.
Sounds good
Like so many things in life.. because it's possible
No, I've had a RPI chip pack for Flowcode but never used it.
RPI's are at this moment not available because of chip shortage. Some sources say until 2023?
ESP32 are very cheap and very available. Also very powerful.
So why not make a component that can be used in FC versions after #9.
- Has thanked: 107 times
- Been thanked: 302 times
As an alternative, there are quite a few "Raspberry Pi" type "clones" that also run Linux, and hence can run Mosquitto.
In particular, I can confirm that Armbian runs well on both Orange Pi and NanoPi Neo.
