MQTT_connect
d820513
Has thanked: 2 times
MQTT_connect
Post by d820513 »
Hi guys !
I can't connect to MQTT broker. What am I doing wrong ?
MQTT_client.fcfx
(16.16 KiB) Downloaded 541 times
Has thanked: 616 times
Been thanked: 815 times
Re: MQTT_connect
The Host URL is longer than 50 characters, maybe try upping the MQTT Client - Host Max Length property to 100?
Also is the username and password of "test" correct?
Finally port 8883 is for encrypted communications which Flowcode doesn't currently support, might be better to try port 1883 which is the unencrypted version.
d820513
Re: MQTT_connect
Post by d820513 »
password and username fictitious.
Hostbroker.hivemq.com. I tried port 1883, it still won't connect. Am I wrong in the macro component?
d820513
Re: MQTT_connect
Post by d820513 »
host: broker.hivemq.com
Re: MQTT_connect
The MQTT component should be connected to a Network comms component, which then connects to the WLAN ESP component. This could be what's causing your problems. The icons should match up.
MQTT_client.fcfx
(16.94 KiB) Downloaded 560 times
If you don't have a username and password maybe try setting Authentication to none.
Some examples here if you're still having problems with publishing and subscribing.
https://www.flowcode.co.uk/wiki/index.p ... IoT/Cloud)
https://www.youtube.com/watch?v=5NFsJTPZKH8
Might also be worth trying to connect via a MQTT app on your phone and see if that can connect ok. Might help you to troubleshoot the various settings.
george_b
Has thanked: 13 times
Been thanked: 3 times
Re: MQTT_connect
Post by george_b »
BenR wrote:
Mon May 23, 2022 2:53 pm
Hi Ben,
Could you please expain how to change the max length of the IOT component for more characters?
mine looks like this "pub-c-6a38f739-6472-425a-a522-e5ec55e3e06a/sub-c-2a445fc0-405d-11ac-b2c1-a25c7fcd9558/Client1"
Thanks in advance
George!
