E-paper display driver (e-inkt / epaper)
MJU20
Has thanked: 105 times
Been thanked: 76 times
Post by MJU20 »
Are there any components underway for use with Epaper displays?
There are many cheap e-paper displays on Chinese webshops that would be a great addition to Flowcode.
Could this be investigated?
Has thanked: 647 times
Been thanked: 856 times
Re: E-paper display driver (e-inkt / epaper)
Yes they should be fairly easy to add support for as long as they are easy to connect to, e.g. not just a fine pitch ribbon cable and have a documented command set or library we can follow. Let us know which ones your looking at and we can investigate.
MJU20
Post by MJU20 »
Thanks for you're positive response:
These look promising:
https://nl.aliexpress.com/item/40013501 ... 5960%21sea
https://nl.aliexpress.com/item/10050027 ... 3529%21sea
The last one uses "Controller IC: IL3829", the first one "GxEPD2 library with the device selection "#define GxEPD2_DRIVER_CLASS GxEPD2_213_Z98c // GDEY0213Z98 122x250, SSD1680"
Thanks they do look good, I've put them into my AliExpress basket and will see if I can get some budget together to get them for testing and development.
I've bought one of each so hopefully they will wing their way to me fast and I can have a play.
I've also had a quick look through the GxEPD2 library and it looks like it should directly support both displays so I'll try and base a component on this if I can.
MJU20
Post by MJU20 »
Sounds great!
Thank you
MJU20
Post by MJU20 »
Any news on this yet? :D
One of the displays has arrived, the other got cancelled by the seller. I'll have a go when I get some time to sit and look at it properly.
MJU20
Post by MJU20 »
Thank you Ben!!
Progress!!! notice that the board is currently powered down, very cool :D
I'm using one of these displays
https://heltec.org/project/154-e-ink/
Purchased from here
https://www.aliexpress.com/item/1005002 ... 1802wqkTbV
Everything seems to work, you write to an internal RAM buffer and then once you're ready you call the Refresh macro to write the buffer to the screen. Downside is you need a ((152 x 152) / 8) or 2888 bytes of RAM free for the display buffer.
I'll have a quick go at partial writes now too so we can also drive the display like a standard GLCD rather then all in one go.
