Goog morning .!!
I'm working on a project using a PIC18F26K22. It is powered by a battery. So I need to conserve the battery.
I want to use a timer to wake up at a specific time to work, and to wait in sleep mode when the work is finished.
Can you give me a simple example or a procedure I need to follow?
Thank you.
MCU(PIC18F26K22) Sleep & Wakeup Mathod?
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
- Has thanked: 595 times
- Been thanked: 785 times
Re: MCU(PIC18F26K22) Sleep & Wakeup Mathod?
It should be as simple as do the job you want the MCU to do. Enable a timer interrupt with the time you want to spend asleep.
Then call this using a C icon.
After the interrupt period the device will reboot and start again from the beginning.
SLEEP();Regards Ben Rowland - MatrixTSL
