I found PIC16(L)F18446.fcdx file has bugs and produces wrong results, at least, on Flowcode 9 .
During compilation FC9 reports errors with interrupts.
The problem is it refers to PIR1bits and PIE1bits, when, in reality,
it should be PIR4bits and PIE4bits .
Please review not only the above described but also other kind of possible errors
in the definitions .fcdx file for this uC .
Here is an excerpt from compilation errors:
16LF18446.c: main()
2424: T1CONbits.TMR1CS = 2;
^ (255) not a member of the struct/union ""
^ (182) illegal conversion between types
int -> volatile union S340
2426: T1CONbits.T1CKPS = 0;
2428: PIE1bits.TMR1IE = 1;
int -> volatile union S899
2455: PIE1bits.TMR2IE = 1;
16LF18446.c: myisr()
3721: if ((PIR1bits.TMR1IF) && (PIE1bits.TMR1IE))
(199) logical type required ^
3724: PIR1bits.TMR1IF = 0;
int -> volatile union S881
3734: if ((PIR1bits.TMR2IF) && (PIE1bits.TMR2IE))
16LF18446.c: 3734: too many errors (21)
(908) exit status = 1
Error returned from [xc8.exe]
PIC16(L)F18446.fcdx with wrong definitions - partially [SOLVED]
miggarc
- Has thanked: 7 times
- Been thanked: 4 times
Many thanks in advance,
Miguel Garcia,
Electronic Systems Developer
- Has thanked: 647 times
- Been thanked: 856 times
Re: PIC16(L)F18466.fcdx with wrong definitions
Hello Miguel,
Many thanks for letting us know.
I have hopefully now solved the problem and pushed the fix to the library update system. I've also added in the other missing timer peripherals.
Please let us know if you spot anything else and I'll investigate for you.
Hi and thanks for you rapid answer.
It is solved ...
Microchip MPLAB XC8 C Compiler V2.10
Build date: Jul 30 2019
Part Support Version: 2.10
Copyright (C) 2019 Microchip Technology Inc.
using updated 32-bit floating-point libraries; improved accuracy might increase code size
Memory Summary:
Program space used 138h ( 312) of 4000h words ( 1.9%)
Data space used 27h ( 39) of 800h bytes ( 1.9%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Data stack space used 0h ( 0) of 7D5h bytes ( 0.0%)
Configuration bits used 5h ( 5) of 5h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Compilation successful!
It is solved ...
Memory Summary:
Miguel Garcia,
