Using Built In Function and Handles to Set values of Variables
jay_dee
Has thanked: 99 times
Been thanked: 69 times
Post by jay_dee »
Hi I have a long series of String Variables.
Row01_C1
Row01_C2
Row01_C3
Row02_C1
Row02_C2
etc...
I am trynig to load data into these Variables based on two paramters 'RxRow' and 'RxColumn'
From previous attempts I have created a Handle variable to build the name of the destination String.
handle = "Row0" + ToString$ (RxRow) + "_C" + ToString$ (RxColumn)
I am now searching for the Built-In Function I need to call to allow me to set the Handle, Property, Value for the destination string variable.
I have previously set the 'sText' property of a Staic Text but I cant see how to do the same to a simple variable?
Any pointers please. :)
Has thanked: 163 times
Been thanked: 960 times
Re: Using Built In Function and Handles to Set values of Variables
Post by mnfisher »
I would investigate the use of an array - you can then use a loop to set static text or whatever.
Has thanked: 292 times
Been thanked: 458 times
I suggest using a 2-dimensional array. For example, "var[5][10]" would create an array which is 5 rows by 10 columns. Just remember that accessing an array starts at zero, so the "top-left" entry in the array is "var[0][0]" and the "bottom-right" is "var[4][9]".
You can then simply use your RxRow and RxColumn to access each "cell" in the array: "var[RxRow][RxColumn]". Just make sure each of RxRow and RxColumn remain in the range of your declared array.
(Martin beat me to it!)
jay_dee
Post by jay_dee »
I did try this approach and failed ...I'll look again now as it is certainly easier to scale rather than building a huge list of strings.
That said.. If I did want to Constuct a target variable name (as described above) ...and then load a number or string into it, can this be done?
J.
I'm pretty sure it can't be done. But I have been wrong before! Arrays definitely sound more appropriate for you though.
jay_dee
Post by jay_dee »
Thanks Steve, I've nearly got a 3D String array doing most of the heavy lifting now. Once it is in a understandable state I'll push it up to get feedback on how to improve it. Thanks.
Post by mnfisher »
A simple example....
I probably should have used x and y instead of i and j
static.fcsx
(41.42 KiB) Downloaded 538 times
Note - I called the first statictext - statictext0 then copy and paste did the numbering for me. Saves adding 1...
jay_dee
Post by jay_dee »
Thanks Martin, That is interesting and very helpful to see how more experianced people have a much cleaner approach to the solution! :)
