PIC 12F629 gpio internal pull-up/down settings
mansiukit
Has thanked: 1 time
Post by mansiukit »
Hi, I have a difficulty to set the code of gpio internal pull-up/down settings. Anyone can teach me how to set the code? Thank a lot!
Has thanked: 633 times
Been thanked: 837 times
Re: PIC 12F629 gpio internal pull-up/down settings
The PIC12F629 only has internal pull up resistors but these can be enabled as follows using a C icon.
OPTION_REG = OPTION_REG & 0x7F;  //Clear GPPU bit enabling pull ups
WPU = 0x11;  //Enable Pullup on GPIO0 & GPIO4
mansiukit
Has thanked: 1 time
Post by mansiukit »
BenR wrote:
Thu Jun 16, 2022 9:41 am
Is it correct? The internal pull up resistors of IOPort 4 is still disable.
Thanks.
You have the C code in between the /* and */ symbols, these are comment blocks and need removing otherwise the code is effectively commented out.
mansiukit
Has thanked: 1 time
Post by mansiukit »
BenR wrote:
Thu Jun 16, 2022 10:46 am
Thank you so much
