It might be my reading of this - in the cal_spi (AVR here) if AutoCS is set to 'yes' - the component should handle pulling CS 'active' on a Transaction.
If AutoCS is 'no' - then it is the user responsibility to pull CS low - transmit - then high.
However - if AutoCS is set to 'no' then Master_Enable_Cs and Master_Disable_CS do nothing - all code pre-processed out (apart from a superfluous string variable being created)
If AutoCS is 'yes' then Master_Enable/Disable_CS do Set_Port_Pin as expected - but the user needs to call them before and after Master_Transaction - as this doesn't toggle the CS pin.
CAL SPI AutoCS
- Has thanked: 158 times
- Been thanked: 943 times
- Has thanked: 607 times
- Been thanked: 803 times
Re: CAL SPI AutoCS
Hello Martin,
AutoCS is maybe slightly misleading, DefineCS might have been more applicable. The thought behind it is as follows.
AutoCS = Yes - The CAL component defines the CS pin and tthe Enable/Diable comp macros will enable and disable the pin - current standard mode.
AutoCS = No - The CAL component knows nothing about the CS pin and the functionality is provided elsewhere - legacy mode.
Currently the transaction macro will never assume and drive the CS pin by itself.
Hope this helps
Hope this helps
