I have a couple of questions regards the Raspberry Pi.
First, is there a specific area on the forum for it as I cannot find one.
Second, Are there any examples how to implement a webserver on one, I have a Modbus (RS485) teperature & humidity sensor I would like read and display the information from it.
Bob
Raspberry Pi questions
RGV250
- Has thanked: 41 times
- Been thanked: 42 times
- Has thanked: 425 times
- Been thanked: 646 times
Re: Raspberry Pi questions
There are no dedicated forum sections for any specific target devices.
Flowcode is target independent and therefore all components should work with all available targets (generally speaking). There are a few examples of creating a webserver in the WiKi and some examples using the Generic component can be found here :-
https://www.flowcode.co.uk/wiki/index.p ... etworking)
Thanks, I think I was getting confused as App Developer has its own section.
On the examples, 2 of them require App Developer so I had a look at the ESP8266 one. It may be me but I cannot see how it works.
I have found a video here https://www.youtube.com/watch?v=DaViZAhSxuQ which seems to be more explanatory and also is for the ESP32 which I have.
Bob
Bob
Last time I used the webserver was in FCv5 with a LAN module so I'm probably not the best to assist. However if you enter ESP32 Webserver in the forum search bar you will get a few pages of hits and I'm sure if you get stuck someone will have had your issue before and can help resolve.
