ESP32-S2-WROOM
minolta
Has thanked: 1 time
ESP32-S2-WROOM
Post by minolta »
Question:
is ESP32-S2-WROOM supported by Flowcode 9?
i want to use WLAN_ESP32 component with this module
Has thanked: 633 times
Been thanked: 837 times
Re: ESP32-S2-WROOM
We haven't tested the s2 version yet. Hopefully it should work ok but you will have to let us know. I'll see if I can get my hands on one to test.
minolta
Has thanked: 1 time
Re: ESP32-S2-WROOM
Post by minolta »
I have to admit that this the first time when i use ESP32 modules.
My intention is to setup a communication between 2 modules, connected to my wi-fi router.
I do not know if this can be done with wlan esp32 library.
But, because i like to try new things i will order 2 modules and do some tests.
I'll let you know how it goes.
TIberiu
Re: ESP32-S2-WROOM
If you are just getting started then I might suggest using the standard v1 ESP32 module. There are lots of boards with the v1 module on.
The IDF compiler that we recommend says it is not compatible with the S2 so there are likely going to be some issues and if you're just getting started then this could be offputting.
Verteyko
Re: ESP32-S2-WROOM
Post by Verteyko »
Добрый день. Не могу прошивать модуль ESPЗ2 DEVKIT1 через USB. Все инструменты скачал и устоновил. Дает ошибку code 0х1
Edit[p.erasmus] English Translation
Good day. I can not flash the ESPЗ2 DEVKIT1 module via USB. I downloaded and installed all the tools. Gives error code 0x1
ESP 32.jpg (79.94 KiB) Viewed 8069 times
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: ESP32-S2-WROOM
Post by p.erasmus »
Добрый день
Команда будет смотреть и сообщать :D
:D
Re: ESP32-S2-WROOM
Здравствуйте,
Как называется ваш проект Flowcode? Не могли бы вы прикрепить его к форумам, чтобы мы могли увидеть, является ли это чем-то особенным для проекта.
What's the name of your Flowcode project? Can you attach it to the forums so we can see if it's something specific to the project.
