Hi!
The devices Pic12f629+675 does not work in FC8 and FC9 I have made the same testprogram in FC5 and there they work as they should.
I have a pic12f683 too, it work perfect in FC9
If I have done something wrong in config, I apologize but really tryed almost everything, please
Br jorgen
Pic12629 + Pic12f675 not working!
- Has thanked: 910 times
- Been thanked: 220 times
- 629.fcfx
- (6.91 KiB) Downloaded 538 times
- (view online)
- 675.fcfx
- (6.89 KiB) Downloaded 665 times
- (view online)
- Has thanked: 311 times
- Been thanked: 479 times
Re: Pic12629 + Pic12f675 not working!
I've tested compilation and simulation and both are ok, but I do not have access to those chips and so I assume you are saying these projects do not run correctly when downloaded to the target chip?
Are the configuration settings appropriate for your hardware?
If you're still having problems, please post the .c and .hex files for both a working v5 project and a non-working v9 project and we will try to discover why there is a problem.
Hi Steve!
FC9: EB board 00-9. When I compile to chip, using internal osc. out to Gp4 I can see the osc out on Gp4 but the program in the loop is not running, the output is not go on and off. For both chip, also tested with Xtal.
FC5: EB board00-7. Working perfect, same program.
I can send you a couble of chip if you want?
I have to send one mail more, only att. 3 files at the time.
Thank´s in advance
Jorgen
Thank´s in advance
Jorgen
- 12F629 FC5 testOk.c
- (2.05 KiB) Downloaded 695 times
- 629TestFC9.fcfx
- (6.91 KiB) Downloaded 680 times
- (view online)
- 629TestFC9.c
- (2.6 KiB) Downloaded 706 times
More Files
I can´t att. the hex file?? for FC9 and not the .fcf either for FC5?
LEt me hear if it not is enough with .C
As I said, I can sen you a couble of chips?
Jorgen
Jorgen
- 675TestFC9.fcfx
- (6.88 KiB) Downloaded 514 times
- (view online)
- (2.05 KiB) Downloaded 559 times
- 12F675 FC5 testOk.c
- (2.13 KiB) Downloaded 643 times
No need to send any chips, but can you attach the two .HEX files as well please?
There is a difference in the configuration settings of the two C code files. The working v5 file has MCLRE set to 0 (ie internally tied to Vdd) whereas the non-working v9 file has it set to 1 (set to the i/o GP3). You might want to change that to see if that fixes it.
If it doesn't then it could be an issue in the CAL.
Hi Steve and Martin
@martin, of course, zip
Steve i give it a go again little later, and make a new compile for both and zip and send. Not at the pc now. (iPad).
Jorgen
Jorgen
Well yes Martin and Steve, hereby
I added also the .hex and the .c file for the 12f683 device compiled in FC9 which work perfect. Could maybe be usefull.
If you need further test, let me hear. (home late aftenoon).
*****Edit. Just perform a test with 12f615 too in FC9, work perfect' the last of these tiny device I have****
Hope it´s not to cold in UK, here in DK up to 37 Degre today
Br jorgen
Br jorgen
- Zip.zip
- (8.11 KiB) Downloaded 620 times
