Could PrintFormattedNumber be added to all displays and not just LCD?
Then gLCD can display Long and Ulong numbers, rather than restricting to signed Ints e.t.c.
Print Formatted Number
- Has thanked: 795 times
- Been thanked: 858 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: Print Formatted Number
Hi Martin,
Good suggestion thanks. I'll have a look shouldn't be too tricky to do
While I'm at it what about a print float function with number of floating points param?
- p.erasmus
- Has thanked: 104 times
- Been thanked: 88 times
This is always useful never mind the application LCD,gLCD even in Serial coms
- Has thanked: 311 times
- Been thanked: 479 times
I realise it's an extra step, but you can always convert the float to a string in a calculation and use the string if the component can't handle the float.
