How can I put Database
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hello?
I have a question.
I want to build a device that acquires data from an embedded board and writes it to a database on a computer.
I want to read data from the embedded board (PIC base) to Modbus and put the value into the address of a specific database (oracle or mssql) of the server computer.
Currently, we are using SCADA SW.
Is there any way to make it?
How can I make it?
Thank you.
Has thanked: 258 times
Been thanked: 414 times
Re: How can I put Database
You might need to call a function in a DLL or maybe use a command-line tool (e.g. mssql-cli). I have no experience with accessing databases in this way though, so can't offer any concrete advice or examples. Perhaps others on the forum can help?
Has thanked: 576 times
Been thanked: 759 times
If you're using a standard LAMP server setup (Linux, Apache, MySQL, PHP) then an easy way is to create a MySQL DB and access this via a PHP/HTML form. Once you have the form that can input data into your database you can do HTML posts from your embedded device. I have both a linux PC (acting as a NAS) and Various Raspberry Pis that I have used to do things like this. The PHP/HTML server can then do additional things like show results in tables/graphs etc and provide backend access to the DB via myPHPAdmin.
https://randomnerdtutorials.com/raspber ... mp-server/
https://www.raghwendra.com/blog/how-to- ... p-example/
Please note I haven't followed the above tutorials, they were the results of quick google searches.
Probably similar methods using Oracle and MSSQL but I've never used these so can't really comment.
Has thanked: 94 times
Been thanked: 288 times
Yes, I would agree with that too.
And if you use the ODBC API in PHP you can connect with pretty much anything (Oracle, mssql or whatever)
Has thanked: 425 times
Been thanked: 646 times
As you already have a database then as Ben suggests it is probably easiest to use the LAMP/WAMP setup with a simple script.
If databases etc are not your thing then you could perhaps use the MQTT/UART Component to update ThingSpeak or any of the similar Hosted offerings.
