I need to set a slower speed for the I2C bus which I have calculated would require the SSPADD registry of my 18LF2550 to be set to 0x63.
I have tried to add some supplementary code defining SSPADD = 0x63. However, the compiler rejects this one line of code.
Can someone help me with the right code to add to the supplementary code section of the Project Options?
Thanks!
How do I modify SSPADD registry with Supplementary Code?
Tortilla
- Has thanked: 9 times
- Been thanked: 3 times
- Has thanked: 92 times
- Been thanked: 281 times
Re: How do I modify SSPADD registry with Supplementary Code?
Supplementary code section is for functions.
Would need to go into a C icon, after the I2C component initialisation.
btw. It is possible to set a custom baud rate in the I2C component
SSPADD = 0x63; btw. It is possible to set a custom baud rate in the I2C component
Ah, thank you for that. No wonder I couldn't set it that way.
I will try to do it in a C icon and also look in to doing it in the I2C component.
Best,
Dan
Best,
Dan
