PCF8574 Read
bierbaum
Has thanked: 2 times
PCF8574 Read
Post by bierbaum »
I fear there is a failure in the PCF8574 module. Whe i write to the expander with the adress 000 it works, but I am not able to read the data from the other chip. When I use the Arduino App, everything works just as it should. Can you please help ?
my regards
TEST_EXPANDER_zwo.fcfx
(15.07 KiB) Downloaded 259 times
Has thanked: 590 times
Been thanked: 778 times
Re: PCF8574 Read
Not sure why this isn't working I've looked through the code and it all seems ok.
If you only have a single PCF8574 component connected to address 1 then does this work. Just wondering if we can narrow down where the problem is.
