ESP32 Timer compiler error
josecastaneda
Post by josecastaneda »
i want to use Timer and Timed Interval with ESP32 Wroom but flowcode V9 don't compile. Some body now my problem?
thanks in advance
Has thanked: 616 times
Been thanked: 815 times
Re: ESP32 Timer compiler error
Please can you post your project and I'll have a look for you
josecastaneda
]Simple timer with out load to main. Only donwload to components. and don't compile
FlowcodeTimerNoCompile.fcfx
(7.47 KiB) Downloaded 299 times
Thanks very much for the file, I'll see if we can add support for the ESP32 hardware.
For now the ESP32 timers are done in a very different way so it might proove tricky to make them do what we want here though I'll certainly have a go for you.
unity-control
Has thanked: 23 times
Been thanked: 11 times
Post by unity-control »
I had the same issue when I started using ESP32.
However I've managed to adapt my program to use custom timers with some variables with minimal code. In other words, you can use a let's say 1ms Interrupt which is what I use at the moment. Inside the Interrupt routine, you just add something like this:
COUNT_TIMER_A_MS = COUNT_TIMER_A_MS + 1
COUNT_TIMER_B_MS = COUNT_TIMER_B_MS + 1
COUNT_TIMER_C_MS = COUNT_TIMER_C_MS + 1
COUNT_TIMER_D_MS = COUNT_TIMER_D_MS + 1
These are used throughout the program and you just count ms with them in your code for things to happen. You can reset them (set the variable to zero) and/or use other variables named for example COUNT_TIMER_A_MS_NOW to do simple maths and trigger events...
I think 1ms of resolution is quick enough for whatever task is needed...
Hope this helps!
R
josecastaneda
Many thanks , for now i forget flowcode v9 profesional. i use free software and this working very nice, BT, SPI(4 devices touch,SD,ILI9341 and max thermocouple). I don't know why when send image to GLCD this is like 10 Seconds Per Frame, instead of 60FPS
