Not sure I have described the title very well.
I am new to flowcode but it probably catches other out as well. I was writing a calculation, when I clicked on OK it told me I had an error and did I want to create a variable. So far so good but I got the variable wrong, here is where the issue is, this time it does not let me edit the variable and I cannot alter the variable without closing the calculation, if I do that it basically deletes everything I have entered.
I think it would be a nice idea if it said there are errors, do you want to save with the error. I now copy the code and paste it back later but I find it a bit annoying that I cannot save it with errors.
Bob
Annoying issue if you have an error in your code
RGV250
- Has thanked: 46 times
- Been thanked: 46 times
- Has thanked: 442 times
- Been thanked: 661 times
Re: Annoying issue if you have an error in your code
If you have an error in your "formula" you need to fix it before closing (e.g. a syntax error)
However you can edit the variable from within the calculation properties box by hovering over the variable, clicking the down arrow to expand the variable and selecting edit.
Hope this helps
Hope this helps
- Has thanked: 292 times
- Been thanked: 458 times
Also, there is an "Allow errors in flowcharts" option in the Application tab of Global Settings. This will allow your calculations (and other icons) to have syntax errors, but obviously these errors will stop you project from being simulated or compiled.
Not ALL variables can be edited. I have noticed that a floating point variable is there to stay. The only way I could edit it (Change it to a non floater) was to delete and start over.
This is intended behaviour because changing between an integer and a floating-point can lead to problems elsewhere in your project. I will look into this and see if there is a better solution - perhaps adding a warning if a user tries to change the variable in this way. Or alternatively I could remove these variable change restrictions if the "Allow errors in flowcharts" option is ticked.
I've just looked into this fix and it is already there in v9. So if you want to swap to different variable types then first ensure that option is ticked in the "application" tab of "global options".Steve-Matrix wrote: ↑Mon Nov 14, 2022 8:58 amOr alternatively I could remove these variable change restrictions if the "Allow errors in flowcharts" option is ticked.
