i noticed whilst looking for an i2S component in flowcode there is one but is named I2S master slave ESP32
1. Is it possible to use this with a dspic ie ECIOP16 or is there a separate one for the dspic
2. i also wish to use the i2s in conjunction with the DSP functions is this feasible i presume it is
David
I2s
DAVIDJOINER
- Been thanked: 18 times
- Has thanked: 595 times
- Been thanked: 785 times
Re: I2s
Hi David,
The ESP32 I2S component won't work but I can certainly have a go at adding support for the I2C peripheral inside the dsPIC ECIOP16 device. I hadn't noticed it was there but I see now it's tucked away inside the DCI module.
As for DSP integration yes that's a great idea and I'll keep this in mind while I'm developing the component.
