Defining or Returning Byte Arrays in User Macros
jay_dee
Has thanked: 99 times
Been thanked: 69 times
Post by jay_dee »
I have i2C read and write macro's . However I dont always want just a single return byte, I might be reading back anything from 1 to 6 bytes.
I see I can Return Strings, Longs, Integers. Can I return a Byte Array from a user Macro?
For the write macro, whilst I can create a parameter Byte Array to hold the 'write' data but how does the user load this array with values using the flowcode user macro interface?
Or am I better just building a set of simpler macros for 1, 2,3,4,6 bytes to be read / written ?
Thanks, J.
Has thanked: 163 times
Been thanked: 960 times
Re: Defining or Returning Byte Arrays in User Macros
Post by mnfisher »
Pass the array as a parameter - if you 'modify' it (or write data to it) it will return the data as you wish.
(Arrays are passed by reference rather than by value - but note that strings have an option to create a local copy)
