PIC24FJ128GB204 IOC simulation and pin config
keithh534
Post by keithh534 »
With interrupts enabled and breakpoints inserted, Flowcode closes after a few seconds at a breakpoint. The pin configurator for the processor only allows "Trigger on both edges".
Has thanked: 510 times
Been thanked: 698 times
Re: PIC24FJ128GB204 IOC simulation and pin config
Please can you post the project that shows this behaviour so we can investigate. There is a known bug in the application regarding simulated interrupt pins which is due to be fixed shortly, likely this week.
keithh534
Post by keithh534 »
It is now 30 December 2022 and the bug is still not fixed. When will it be addressed?
Has thanked: 214 times
Been thanked: 362 times
The bug Ben was referring to was fixed at the beginning of November. Please see this post for the details.
I am not sure if this relates to your problem. As Ben said, please post an example project showing this behaviour and we'll be happy to look into it.
