any advice about the following issues with attached flowcode fcfx please
issue 1: my understanding of arrays in flowcode is that a string array variable; array_name[3] should allow 4 string array entries (0 -3) with a default length of 20 to be used in a calculation box, this does not appear to be the case, I have had attached the string length to the variable definition to get it to accept a text string in the calculation box. what is the correct structure. flowcode wiki does not make it very clear
issue 2: why the attached flowcode appears to add the array index to the end of the string to be printed apart from the last. i have tried it with a ssd1306 display with the same result. this is simulation only, I haven't tried actual hardware yet
issue 3: when I compile it using pic16f1769 the complier generates the error below. if I use the pic16f18877 it compiles just fine. both chips have same sdram. it's not program size as when it compiled, only 20% was used
ssd1322_new_rig.c: 549: (1250) could not find space (2048 bytes) for variable _FCV_07241_gLCD_SSD1322_buffered1__DRAM
attached are compilation text files
Array & compilation problem
Maverick
- Has thanked: 27 times
- Been thanked: 8 times
- ssd1322_new_rig_16f18877.msg.txt
- (2.72 KiB) Downloaded 388 times
- ssd1322_new_rig_16f1789.fcfx
- (15.57 KiB) Downloaded 402 times
- ssd1322_new_rig_16f1789.msg.txt
- (2.27 KiB) Downloaded 305 times
- Has thanked: 156 times
- Been thanked: 909 times
Re: Array & compilation problem
x[3] just creates a string with 3 characters. To create an array of strings you need
x[4][20] to create an array of 4 x 20 character strings.
You can access these as x[0] .. x[3]
