d-a dac pins
Maverick
Has thanked: 27 times
Been thanked: 8 times
d-a dac pins
Post by Maverick »
Looking at using an external DAC , preferably the MCP48x1 o2 49x1 as they are available to buy easily. Problem is these 2 devices in flowcode do not have the remap pin option that the 4725 and 47x6 or port change which the AD5662 has. Is there a reason for this or can editable pins be added.
Also, just out of interest most of the pic micros have dedicated spi pins, normally RB6 & RB7, why is it that the flowcode parts use other ports?
Has thanked: 665 times
Been thanked: 744 times
Re: d-a dac pins
Hi, Maverick.
Thank you for the spot.
I have fixed the remapping issue, and the componets will be pushed onto the update system as soon as possible.
If you would like to try the components before the updates are pushed.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
Replace the existing file with the attached files.
If you run any component updates, then the components you added will be overwritten, so you will need to bare that in mind.
DAC_MCP48x1.fcpx
(6.19 KiB) Downloaded 226 times
DAC_Output_Dual_48x2.fcpx
(6.36 KiB) Downloaded 336 times
Maverick
Re: d-a dac pins
Post by Maverick »
Thanks again for the prompt response
Re: d-a dac pins
You're welcome.
Flowcode v9 updates have now been pushed.
Maverick
Re: d-a dac pins
Post by Maverick »
Hi Martin
can the same be done for the mcp49x1 part please
Re: d-a dac pins
Hi, yes that is on the list to be done.
Rather than in dribs and drabs, I have decided to fix all components that have the same issue.
They will be all pushed on the update system at the same time.
