fround does not appear to work
RGV250
Has thanked: 46 times
Been thanked: 48 times
Post by RGV250 »
Please move if it is not a bug but I have tried to round some values and it does not appear to work.
This is the output to the web browser, the power values should be rounded to 3 decimal places.
Values not rounded.jpg (43.92 KiB) Viewed 3998 times
RPI_EcoEyeMonitor_V1_4A.fcfx
(37.95 KiB) Downloaded 425 times
Bob
RGV250
Re: fround does not appear to work
Post by RGV250 »
Also tried without the space between the "fround" and the bracket, still no good.
Has thanked: 795 times
Been thanked: 858 times
I have noticed your float calculations don't have a decimal point within them.
What you need to do is force constants to float type by adding .0 at the end.
For example instead of
Sensor_1_Power = Sensor_1_Current * 240 / 100000
Use
Sensor_1_Power = Sensor_1_Current * 240.0 / 100000.0
RGV250
Post by RGV250 »
I have tried adding .0 as above but still the same, I then wondered if it was because the current value was not initialised so I added 0.0 to the initial value but still the same.
My only other thought was if it was due to the HexStrToInt macro returning an Int but I cannot figure out how to change the .Return value to a float.
Bob
Has thanked: 647 times
Been thanked: 856 times
Hi Bob,
The problem isn't the fround function, you shouldn't need to call this. The problem is the FloatToString$ function defaults to 6 decimal places,
Sensor_1_CurrentWeb = FloatToString$ (Sensor_1_Current)
Change to this instead.
Sensor_1_CurrentWeb = FloatToString$ (Sensor_1_Current, 3)
Or you can bypass the conversion altogether and instead of calling SetOutValue you can call the new SetOutValueFloat macro to pass the floating point value directly.
RGV250
Post by RGV250 »
Hi Ben,
thanks, I forgot you added the SetOutValueFloat for me, it works a treat and does save code.
One question, does this do any rounding or just limit to x dec places. In this instance it is a very tiny value anyway so not worth worrying about but just thought I would ask in case I only go to 1 DP.
Bob
Hi Bob,
It should round for you.
so 1.56 with 1 DP would display as 1.6
