dvcam99
Posts: 109 http://meble-kuchenne.info.pl
Has thanked: 9 times
Been thanked: 14 times
Post
by dvcam99 » Mon Jan 25, 2021 9:19 pm
Hello Matrix Team,
below you will find a shorts ESP-32 UART 9Bit opperation test program. This will show the situation.
Very positive in this context is that manual baud rate is working!!
To be very honest this missing 9Bit opperation is at the moment a show stopper in order to purchase a FC professional 9 upgrade for me.
Maybe this is an easy fix for you brillant experts!!
THX and BR
Dirk
Happy FC9, FC-8 and FC-6 professional user
Posts: 539 Joined: Mon Dec 07, 2020 1:00 pm
Has thanked: 98 times
Been thanked: 294 times
Post
by LeighM » Tue Jan 26, 2021 8:18 am
Hi Dirk,
The ESP32 UART driver does not support 9 bit data,
so you will not be able to send for example 0x1f0 as in your program.
However, if 8 bit data plus parity is what you need, then please try this ...
Set the Flowcode UART property to 8 bit
and add this C code ...
uart_set_parity(1, UART_PARITY_EVEN);
dvcam99
Posts: 109 Joined: Fri Dec 04, 2020 11:03 am
Post
by dvcam99 » Tue Jan 26, 2021 10:09 pm
Many thanks Leigh,
it works fantastic!! It´s is much better compared against my PIC UARTS.
I got rid of my complicated old parity calculation!!
In case that sombody wants to activate two stop bits!! Below the syntax for ESP32 compiler:
uart_set_stop_bits(1,UART_STOP_BITS_2);
BR
Dirk
Post
by LeighM » Wed Jan 27, 2021 7:52 am
Hi Dirk,
Glad to hear, thanks for letting us know
Leigh
