dsPIC30F6014A - ADC reading problem
egearabaci
Has thanked: 3 times
Been thanked: 2 times
Post by egearabaci »
Hi all,
I got a problem with the analog pins of dsPIC30F6014A controller. I think it reads the voltage at the ADC pins wrong. I am using Flowcode 9.3 and reading the ADC pins with component macro's GetVoltage.
I checked the voltage directly at the ADC pin of controller with a multimeter and its correct. I used a decision block that lights up a LED if the read voltage is not in the wanted interval, but it lights up the LED even read voltage is in the interval. I do not know if there is an offset on the controller's ADC pins.
It happened with different PCBs with same design and circuits with different designs using same controller. It happened with all cases.
Also there is an interesting situation here, when I used Flowcode 7, it reads the ADC pin closer to the real value.
Thanks.
Has thanked: 635 times
Been thanked: 842 times
Re: dsPIC30F6014A - ADC reading problem
Please can you attach your project file so we can have a look for you.
egearabaci
Sorry for the late reply and thanks for helping,
I attached the mentioned code file.
In attached file;
If I compile the code through the Flowcode 9.3, it turns on the error LEDs (LED situations is in the LEDS macro.) even if there are no problems with voltage on designed PCB.
If I compile the code through the Flowcode 7, it does not turn on the error LED as I expected.
Everything is same with both situations, did not change a single thing in code.
Thanks.
flowcode.fcfx
(74.17 KiB) Downloaded 603 times
Many thanks for letting us know. I've put together what I hope will be a fix based on the differences between the v9 and v7 code and hopefully this should help the situation.
I've pushed the changes to the Help -> Library Update system so you should be able to get the latest from there.
Please let us know how you get on.
egearabaci
Thanks for fast reply.
My computer that I am using for Flowcode does not have access to the internet. Can you attach the updated library file so I can implement it?
Thanks again.
The file is available here and needs to be placed into this directory. Please note it is hidden by default so copy and paste the path into your file explorer address bar.
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\PIC16BIT
PIC16BIT_CAL_ADC.c
(95.16 KiB) Downloaded 685 times
egearabaci
I updated the file and tried again. This time it worked smoothly.
But there is another problem here. Code runs slower when the hex file is compiled through Flowcode 9.
I noticed it because of the LEDS macro that runs 4 LEDs by binary counting.
Thanks.
WingNut
Has thanked: 56 times
Been thanked: 43 times
Post by WingNut »
I'll give it a go when I get home.
Think i tried the physical rotation but i'll confirm
