PI Pico compile errors
Maverick
- Has thanked: 27 times
- Been thanked: 8 times
I've installed the pico toolchain as per the attached pdf, started new project flowcode1.fcfx (attached). when I try to compile to hex it fails; the compile log flowcode1.msg.txt is attached. please advise
- Flowcode1.msg.txt
- (2.19 KiB) Downloaded 254 times
- Installing the Pico toolchain on Windows 10 & Sending your Program to the Pico.pdf
- (525.15 KiB) Downloaded 228 times
- Flowcode1.fcfx
- (7.59 KiB) Downloaded 264 times
Re: PI Pico compile errors
Hi Leigh
Thanks for that, it appears to have worked (log attached).
- Flowcode1.msg.txt
- (13.96 KiB) Downloaded 237 times
