Pi Pico compile error
liudeqiang_2008
Has thanked: 11 times
Been thanked: 2 times
Post by liudeqiang_2008 »
Hello ,
Follow the Pico toolchain installing instruction, I have installed all the components, GCC,CMake,Visuall Studio...
When tring to compile the program to Pico, there is error coming out:
Target folder: E:\Programming\Flowcode Project\Learning
Source name: E:\Programming\Flowcode Project\Learning\test1.fcfx
Title:
Description:
Device: PICO.PICO.Raspberry_Pi_Pico
Generated by: Flowcode v9.3.1.36
Date: Tuesday, December 13, 2022 00:39:05
Users: 1
NOT FOR COMMERCIAL USE
https://www.flowcode.co.uk
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat "C:\Users\liude\pico-sdk\pico-sdk\" "test1" "E:\Programming\Flowcode Project\Learning\"
E:\00 Inspetrel Industry\09 Programming\Flowcode Project\Learning>REM CRC: 11E85D0BF540A03612B9D5AB8A950728A3654FDC084B783F85B503651504FC6E8DA967745A187CF8FECF9115B25085A2774D1D3D69D8A99EE7320EAE740A5DB66BD212DE98DE91D9E3564078A19D1616A5C2ACA5856A86664D00059D79589982019B1EBDA9F75E245824CF181DE22D23B9DE25CDF0E36405D9066202E94705CBBDB038842E43FA4AAC72934211FD4B5DCC661788BEC7C91A063848616D51551DB978AC1A4BAF29AD4517DCDD22FC70DE135D32748FB3D1732C3050DA273BE4EE39DD52E8224900600B1F9528E97AB0BA001B0922CEB719397C7C0C9FABE651313F9A05C84301D1C0
E:\Programming\Flowcode Project\Learning>REM REVISION: 2.0
E:\Programming\Flowcode Project\Learning>REM GUID: 9EF5601F-D979-495F-89EB-F1C4F35D9212
E:\Programming\Flowcode Project\Learning>REM DATE: 30\07\2021
E:\Programming\Flowcode Project\Learning>REM DIR: FCD\PICO\batch\pico_build.bat
Building test1 ...
系统找不到指定的路径。
PICO_SDK_PATH is C:/Users/liude/pico-sdk/pico-sdk
PICO platform is rp2040.
CMake Error at C:/Users/liude/pico-sdk/pico-sdk/CMakeLists.txt:10 (project):
Running
'nmake' '-?'
failed with:
绯荤粺鎵句笉鍒版寚瀹氱殑鏂囦欢銆?
-- Configuring incomplete, errors occurred!
See also "E:/Programming/Flowcode_Project/Learning/test1/CMakeFiles/CMakeOutput.log".
'nmake' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
Build Failed
C:\ProgramData\MatrixTSL\FlowcodeV9\FCD\PICO\Batch\pico_build.bat reported error code 0x1
Autoclose turned off
FINISHED
It looks like someting wrong with CMake, I have reinstall it, still the same issue.
Could you support me for solving this problem?
Thanks,
Regards, Deqiang
Has thanked: 704 times
Been thanked: 768 times
Re: Pi Pico compile error
Can you create a folder test folder on the c drive e.g.
C:\PicoTest
and see if your project then compiles OK?
