help termistor setting 104GT-2
d820513
Has thanked: 2 times
Post by d820513 »
thermistor semitec 104GT-2
0 - 300с
how is the correct flowcode setting for this thermistor
an example if possible, thanks
Has thanked: 724 times
Been thanked: 783 times
Re: help termistor setting 104GT-2
hello.
You will need to add the Thermistor component.
Look at the thermistor datasheet then enter the values within the thermistor component properties.
d820513
Post by d820513 »
where to get this value ?
where to get this value.png (163.77 KiB) Viewed 2411 times
d820513
Post by d820513 »
i can't figure it out
Has thanked: 442 times
Been thanked: 661 times
There doesn't seem to be a lot of results if you search for the 104GT2 resistance table, but as many 3D printers use this component you may get better help from one of their sites.
This link documents a table, but you might want to search further.
https://e3d-online.zendesk.com/hc/en-us ... stor-Table
Hope it helps.
What I just did is enter the standard formula in excel for deriving the resistance for a given temperature.
These are the results:
R vs Temp 100k.png (9.57 KiB) Viewed 2388 times
You can either enter those values within the component properties or use one of the many online calculators, since the beta value is shown on the datasheet.
Another option is to use a formula to display the temperature.
I posted a project doing that, here.
