Scroll one line only
ctesla75
Been thanked: 2 times
Post by ctesla75 »
Hi All,
Have just got flowcode v9 mainly to play with esp32. I am trying to scroll just the first line of a display and keep the second line static. I have seen it done in C but I am wanting to do it in flowcode as I am not a C programmer
ctesla75
Re: Scroll one line only
Post by ctesla75 »
Here is my attempt ,My idea was to clear the line i wanted to be static and reprint it at the same posistion after scrolling the whole display
scroll.fcfx
(9.88 KiB) Downloaded 295 times
RGV250
Has thanked: 41 times
Been thanked: 42 times
Post by RGV250 »
I am sure there is a better way but this does what I think you want.
scroll_1.fcfx
(9.27 KiB) Downloaded 409 times
Bob
Has thanked: 154 times
Been thanked: 884 times
Post by mnfisher »
This is one way: Oops - too slow - now this is another way...
I've gone with a 'rotating' message - but you could just print relevant part of string.
Scroll2.fcfx
(10.82 KiB) Downloaded 436 times
ctesla75
Post by ctesla75 »
Hi Martin ,
Thanks for the reply your code does what i want i just swapped which line rotates , excuse my ignorance but i cannot figure out how to change the abc lettering for my text
ctesla75
Post by ctesla75 »
HI RGV250,
Thanks for the reply, your code seems to do what i want but i cannot figure how to modify it i wanted the bottom line to be static
i tried changing the position in the cursor without luck, I also wanted the display to rotate and put an if statement tom jump out of it, instead of looping 16 times
Post by mnfisher »
Glad to help..
The text displayed is scrollText (a local variable in main) - the 'abcde' is set in it's definition - I've modified to set in a calculation block. Note that to allow longer strings - untick 'make a local copy' in the display macro and use the length of the string instead of 16 too..
Something like:
Scroll2.fcfx
(11.5 KiB) Downloaded 539 times
Note that the string passed needs to have at least 16 characters as the code stands..
MArtin
RGV250
Post by RGV250 »
I have swapped the lines and added a comment, I am quite new to Flowcode so will need read up a bit on how to break out as I think comparisons only work on strings.
scroll_1A.fcfx
(9.89 KiB) Downloaded 383 times
Bob
ctesla75
Post by ctesla75 »
Thanks for the help everyone, I have some working code now. No its time to slowly figure out the resr
