Display manager component usage
KikeRico
- Has thanked: 2 times
- Been thanked: 8 times
Hi, I´m triying to use Display Manager componet but is not clear for me how to use it. Please could help me with some example? thanks.
- Has thanked: 649 times
- Been thanked: 856 times
Re: Display manager component usage
The display manager is a bit under development and improvement but the basic functionality can be seen here.
Please note in putting this example together I have found and fixed some problems and these have been pushed to the Help -> Library update system.
I'm not too happy with it yet so if you have any ideas or suggestions then that would be appreciated. A simple improvement might be to have the textfield object be bounded and multiline like the textfield component.
There is also the question of bg/fg colour and clearing of the display, at the moment this is handled by the user to make things as flexible as possible but the component could perhaps be doing more.
- Has thanked: 478 times
- Been thanked: 713 times
I see you updated the WiKi and it does contain the info needed to create an object, but it seems a little over complicated compared to other Macro's. Would it be possible to just enter a byte value to indicate the type (e.g. 3 = Type_Rectangle) with perhaps the tool tip informing what the byte signifies?
Just a thought.
Just a thought.
Yes good suggestion I'll add the numeric values too and update the tooltip.
KikeRico
Hi Ben,
I have reviewed the example and took a look in the wiki, now is more clear for me how could be use this component. I really appreciate your effort. Thanks a lot
Now I will try to do some programs using the Display Manager, then I think I'd back with some suggestions.
Best regards,
Kike
Best regards,
Kike
